Texas Instruments today introduced a new family of digital-to-analog converters (DACs) that enables engineers to increase the accuracy and performance of programmable logic controller (PLC) I/O modules, field sensors and transmitters, and building automation systems, while decreasing overall system size and cost. The DAC8760 family is also the industry’s first to provide simultaneous voltage and current outputs, giving system designers the flexibility to use either one or both outputs.
Key benefits of the DAC8760 family:
Highest precision: Maximum total unadjusted error (TUE) of 0.1 percent, eliminating the need for calibration.
Highest integration for reduced board space and bill of materials: Each device in the family includes voltage output, 4- to 20-mA output, precision reference and low-dropout regulator (LDO), along with on-chip reliability and diagnostics via a watchdog timer and cyclic redundancy check.
Greater design flexibility: Designers can program the ranges for voltage and current outputs using the serial peripheral interface (SPI).
Widest temperature range: Supports temperatures ranging from -40 to +125˚C, 32 percent wider than similar DACs.
Texas Instruments
Filed Under: Power Electronic Tips
