GT-41134-0606-W2-TAB Model is addition to GlobTek’s GTM41134 family and represents GlobTek’s 6 Watt wall plug-in series of AC/DC adapters with fixed or interchangeable blades. These converters are ideally suited to provide reliable power globally, as it features factory-configurable outputs ranging from 5Vo to 48Vo, with 0.1Vo increments, fixed or changeable input blade system with individual field replaceable input plugs, including: North America / Japan NEMA 1-15P, Australian, UK BS 1363, European CEE 7/16 configuration, Korean KS C8305, Argentina IRAM 2073, China GB, India IS 1923 6A/SANS 164-3/BS546, IEC320/C18 Inlet, Brazilian NBR6147, S. African SANS 164-1 and British Standard BS 546-15A configurations and Global Regulatory & Safety Approvals and Certifications.
This series features Regulated outputs with very low ripple, built-in overcurrent, short circuit, overvoltage and thermal protection, as well as low leakage, low ripple, and high efficiency.
GlobTek’s GTM41134 series of enclosed power supplies are housed in Impact resistant non-vented Polycarbonate Thermal Conduction-Cooled Cases.
Certifications / Approvals / Safety Compliance:
- IEC 60601 for Medical EMC Has Immunity & Risk Management
- UL 60335-2-34 Safety of Household and Similar Electrical Appliances, Part 2-34: Particular Requirements for Motor-Compressors
- IEC 61558-1:2005+A1:2009 deals with safety aspects of power transformers, power supplies, reactors and similar products such as electrical, thermal and mechanical safety. This standard covers the following types of dry-type transformers, power supplies, including switch mode power supplies, and reactors, the windings of which may be encapsulated or non-encapsulated.
Our certification is accepted by the OSHA Nationally Recognized Testing Laboratory (NRTL) Program which is required for demonstrating compliance to UL standards for switching power supplies. GTM41134 are certified 2xMOPP (means of patient protection), which refers to two independent systems of insulation protecting the patient from dangerous voltages. A single insulating component can get this rating based on extensive testing. 2xMOPP certifications exceeds the requirements of 2xMOOP and these power supplies may be used for either application. In addition the series complies with 60601-1-11 Home health care standards.
Aside from 2xMOPP rating, the model is designed to withstand ESD surge ratings of 8kV Contact / 15kV Air.
GTM41134 Family also complies with North American Energy Star, Canadian NRCAN, EISA, EuP, and other worldwide requirements for Level V efficiency compliance and is produced in an ISO13485 certified facility. IEC 60950-1 2nd edition or IEC60601-1 3rd edition and have certifications by UL (North America), C-Tick (Australia/New Zealand), IRAM (Argentina), BSMI (Taiwan), CB (Worldwide), CCC (China), Demko (Europe), eK (Korea), NRCAN (Canada), Spring (Singapore), SIQ (Europe), GOST (Russia), Singapore (PSB), and UkrSEPRO (Ukraine). They also comply with Canadian NRCAN efficiency requirements as well as FCC/VCC/CE EMC requirements.
Options:
Bespoke, customized enclosure colors, output connectors, housing designs, output cord types and lengths, customized packaging, including open frame or ruggedized to various degrees of Ingress Protection. Test reports and certifications as well, as variety of other customizations or options is available upon request.
These products can be supplied with customer designated output plugs, many of which are stocked at GlobTek New Jersey USA, Münster Germany, and Suzhou China locations.
Made in USA or Made in China options available. Local China to China delivery is available upon request.
Applications:
This family of Industry’s high density wall plug-in AC-DC converters is suitable for most applications requiring DC power which include industrial, marine, consumer or medical devices, portable medical treatment and monitoring equipment & instruments, hospital equipment and fixtures, Lighting and Support Equipment, medium and high power appliances or consumer products, VOIP phones and telecom equipment and are a perfect power source for rapid Li-Ion and other emerging chemistries battery charging.
GlobTek
en.globetek.com
Filed Under: Power supplies, Power Electronic Tips
