The CT-S range of time relays and CM range of measuring and monitoring relays features two new innovative connection options: Double-Chamber Cage Connection terminals and Push-in terminals. The connection terminals use screw technology, connect with two wires in diameters up to 14 AWG, solid or stranded, with or without wire-end ferrules. The Push-in terminals feature spring clamp, and Easy Connect technology. With the Easy Connect option, solid or stranded wires with ferrules can be connected without a tool, and stranded wires, without ferrules, can be connected with a screwdriver. The Push-in terminals come in solid or stranded wires up to 20 – 16 AWG.
ABB
www.abb.com
Filed Under: Terminal blocks
