IDEC is expanding our relay selection by introducing the new 6mm RV8H interface relays with a UL listed Class I Division 2 rating, designed specifically for use in hazardous locations. These interface relays are suited for controls used in applications such as oil and gas equipment, panel building, refineries, painting and mixing chambers, mining, waste water treatment and other locations that may require a slim 6-amp switching capability in a compact space.
Corresponding SV1H series sockets from IDEC are also UL listed (with the relay) for Class I Division 2 hazardous locations and are available with spring clamp terminations or traditional screw terminations. With a socket height of only 70mm from the DIN rail, our terminals have a low profile, providing a compact solution for general purpose relay and socket requirements including those requiring miniaturization of machines and panels. Not to mention, installation time is greatly reduced with the spring clamp terminals.
RV8H relays have undergone rigorous quality control testing and contain only the highest-quality materials. Gold-plated contacts, for low level switching, are standard with a maximum of 6A switching loads. Operating temperatures range from -40 to +70° C for up to 60V AC/DC input. Plus a wide input voltage range from 6 to 240V.
IDEC
www.IDEC.com/usa
Filed Under: MOTION CONTROL, Relays, ELECTRONICS • ELECTRICAL
