With an IP69K rating, LF1D LED lighting units can now be used in environments requiring a high degree of protection from dust, as well as the ability to withstand high-pressure and high-temperature spray-downs. This rating makes them ideal for machine tools, food and beverage processing, bottling, pharmaceutical, transportation (road vehicles such as cement trucks that require regular, intensive cleaning) and waste water treatment markets.
These compact LED light strips are the brightest in their class at 67.2 Lumens/Watt (Wide) and 66.6 Lumens/Watt (Slim) respectively. Plus the LF1D Series retains 70% of its initial luminance at 50,000 hours! Offered in Cool White (Temp: 5700K), slim (10 x 1 LED array) or wide type (7 x 2 LED array) with 24V DC voltage, all LF1D light strips are manufactured with a sturdy die-cast aluminum housing and stainless steel front cover. LF1D light strips are also RoHS compliant, mercury-free and UL listed.
Two cable options are available: Side connection and Back connection. Plus a removable direct plug-in terminal block and spring clamp connections ensure a high-quality connection.
Filed Under: Machine tools + subtractive manufacturing, Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
