In our newest Design World publication, The Motion Control Handbook—Trends, our editorial team talked to hundreds of companies to learn about new trends in their markets and applications. This publication, set to come out later this month, features commentaries on products ranging from cables to cable carriers, motors to ballscrews, encoders to transducers and many more. In addition, we look at specific markets where motion control technologies are prevalent and find out what the future holds in these areas.
In this first part of a series on cable trends, I spoke with five different cable manufacturers about which industries are making the most impact on their designs. Here are some key takeaways from our conversations, which showed that labor-intensive and automated processes are clearly using more industrial servomotor cables than ever before and what other industries have been key in the design innovations of these components.
Automation is number one
Any industry where automated machinery is in use has had a tremendous effect on cable designs, including warehousing and distribution, automotive manufacturing, food and beverage, as well as others. These repeatable, high-speed and often high-power applications require safe, flexible designs.
“As all types of industrial automation advances to be more productive, machines are running at higher speeds than ever before,” said Rick Orsini, Product Manager at SAB North America. “As these industries take advantage of the advances in robotics, the need for faster communications and faster motors/drives require more movement and more flexible cables to go along with them.”
In high-pressure, repeatable manufacturing like stamping presses, tension on bolster cables is critical for safe designs, said Tim Hannigan, cable engineer, TPC Wire & Cable.
“One of the things that we’ve been able to do is use insulation that can withstand multiple repeated flexing cycles that you don’t need a real thick wall on. You can use a thin wall so it reduces the size. The caveat on that, on the backside of that, is it’s going to be a more expensive cable, because you’re using materials and techniques that just are very costly to use to begin with,” Hannigan said. “It may cost you a little more on the front side, but you’re going to save all kinds of money on the back side.”
Designing with health in mind
Most agree that a lot of recent changes have been spurred by the medical industry, with designs that are hygienic, safe and extremely durable.
According to Neal Allen, key account/industry manager, HELUKABEL USA, “We see more motion cables in the medical industry as they increase their use of robotics in more advanced applications. These machines need anti-microbial cables for these applications, which we can provide.”
TPC’s Hannigan added that X-ray and MRI machines are requiring reliable motion cables to prevent downtime. These medical-grade cables must also meet FDA directives, Hannigan said.
And, said Rich Buchicchio, national sales and marketing manager for Cicoil, hospital equipment like other labor intensive industries “require a 24/7 labor force, uninterrupted service, accuracy, and no injury issues from their cable designs.”
Materials to match harsh environments
To survive harsh environments, like machine tool, mining and construction, special jacketing materials have been developed to protect both the cables and their users.
TPC’s Hannigan said that cables used in construction equipment construction most withstand the chemicals used in those industries. And HELUKABEL’S Allen added that the machine tool industry requires more motion cables that can withstand cutting fluids and oils, making it even more challenging to cable designers.
“The biggest change in the last five years in the U.S. for cable designers has been the need for UL listing, in many cases tray requiring cable exposed run (TC-ER) approvals. Even though the cable track sections of a system are exempt from the NFPA requirements, what happens to the cables once they exit the cable tracks is routinely scrutinized by local inspectors,” Allen said. “In many cases, the cables are put in trays to get to the control panels. However, having two different designed cables in the system—one being the cable track and the second being the tray cable—is not cost effective, so we designed the track cables to be tray rated cable as well, which is very difficult to do.”
Additionally, Allen said, tray rated cables use flame retardant additives to meet FT-4 requirements. “The additive helps to extinguish flames but reduces the elastic properties of the compounds used in the insulation and jacket materials. We are always challenging compound manufacturers to help us retain good continuous flex properties while still meeting the necessary flame requirements,” Allen said. “Ford Motor Company recently addressed this issue with their latest power train specification, which is primarily a conformance requirement for their machine tool equipment suppliers to use TPE-based cables that are UL tray cable approved.”
Stay tuned for more thoughts from these industry leaders on technological advances, manufacture and distribution and prominent designs in the cable industry.
The post What industries are making the most impact on cable designs? appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
