The LP+ Generation 3 precision gearhead for drive systems is economical. With the same space envelope requirements as the LP+, it is a drop-in replacement; yet, it has higher power, smoother running and more ratios. The design possesses up to 75% more torque. For servo applications in packaging, handling and automation systems, the output can optionally be designed with a smooth or keyed shaft. It is also available with output flange and in a 2-stage version with increased ratios.
Wittenstein
www.wittenstein-us.com
Filed Under: Gears • gearheads • speed reducers, Motion control • motor controls
