Ondrives.US Corporation (formerly Rino Mechanical), announces its right angle NEMA gearbox designed to IP65 specifications for use in wash down applications in packaging equipment and similar machinery. Rated backlash is 30 arc-minutes with options for 4 or 8 arc-minutes. The NEMA 34 flanged gearbox has 440C Stainless steel bearings with seals and Nitrile o-rings shaft seals on both input and output. All fasteners are stainless steel. Hard anodized aluminum or 316 Stainless housings are available. Customizing for other than NEMA motors or your specific application is easily done.
Ondrives.US Corp.
www.ondrivesus.com
Filed Under: MECHANICAL POWER TRANSMISSION, Gears • gearheads • speed reducers, Motion control • motor controls
