ACCES I/O Products, Inc., has announced the release of a new family of PCI Express Mini Cards, the mPCIe-ICM Series. These isolated serial communication cards measure just 30 x 51 mm and feature a selection of 4 or 2 ports of isolated RS232 serial communications. 1.5kV isolation is provided port-to-computer and 500V isolation port-to-port on ALL signals at the I/O connectors. The mPCIe-ICM cards have been designed for use in harsh and rugged environments such as military and defense along with applications such as health and medical, point of sale systems, kiosk design, retail, hospitality, automation, and gaming.
The RS232 ports provided by the card are 100% compatible with every other industry-standard serial COM device, supporting TX, RX, RTS, and CTS. The card provides ±15kV ESD protection on all signal pins to protect against costly damage to sensitive electronic devices due to electrostatic discharge. In addition, they provide Tru-Iso port-to-port and port-to-PC isolation. The serial ports on the device are accessed using a low-profile, latching, 5-pin Hirose connector. Optional breakout cables are available, and bring each port connection to a panel-mountable DB9-M with an industry compatible RS232 pin-out.
The mPCIe-ICM cards were designed using type 16C950 UARTS and use 128-byte transmit/receive FIFO buffers to decrease CPU loading and protect against lost data in multitasking systems. New systems can continue to interface with legacy serial peripherals, yet benefit from the use of the high performance PCI Express bus. The cards are fully software compatible with current PCI 16550 type UART applications and allow for users to maintain backward compatibility.
The mPCIe-ICM Series is especially useful in applications where high common-mode external voltages are present. Isolation is required to guard electronics from transient voltage spikes and offers greater common-mode noise rejection in electrically noisy surroundings containing industrial machinery and inductive loads. These applications include factory automation, energy management, military/mission-critical, industrial ON/OFF control, security systems, manufacturing test, process monitoring, and kiosks. In addition to protecting industrial applications from the influence of high external voltages, isolation eliminates troublesome ground loops.
Key features of the mPCIe-ICM family include:
-PCI Express Mini Card (mPCIe) type F1, with latching I/O connectors
-4 or 2-port mPCIe RS232 serial communication cards
-Tru-Iso 1500V isolation port-to-computer and 500V isolation port-to-port on ALL signals
-High performance 16C950 class UARTs with 128-byte FIFO for each TX and RX
-Industrial operating temperature (-40°C to +85°C) and RoHS standard
-Supports data communication speeds up to 1 Mbps simultaneously
-Custom baud rates easily configured
-±15kV ESD protection on all signal pins
-9-bit data mode fully supported
-Supports CTS and RTS handshaking
Software
A complete driver support package is provided including an easy-to-use Windows terminal program for testing your COM ports. This simplifies the verification of proper COM port operation. The cards install as standard COM ports in all operating systems including DOS, Linux (including Mac OS X) and 32-bit and 64-bit Windows. Additional drivers may be available for a wide variety of operating systems including Windows CE, please contact ACCES for compatibility with your specific OS.
Prices range from $139 to $199, depending on model
Availability: Now
Delivery: Stock to two weeks ARO
www.accesio.com
The post Isolated PCI Express Mini Card appeared first on Micro Controller Tips.
Filed Under: Automotive, Medical-device manufacture
