Iwaki America Inc. offers new material options for their SMX series of magnetically driven non-metallic self-priming pump line. The fluoroplastic SMX-F incorporates their proven self-radiating bearing design and dry run rated non-contact system, these true self-primers incorporate integrally molded priming and air separation chambers for repeatable self-priming in a compact package. Flows to 90 GPM, heads to 80 FT, the SMX-F is constructed of CFR-ETFE with available bearing systems of carbon, PTFE and silicon carbide. With two impeller ranges available for each model an efficient, reliable selection is available for a range of corrosive self-priming applications. Uses standard NEMA C-face motors for versatility in installation options.
SMX-F designs utilize a robust internal design ensuring maximum reliability under adverse operating conditions. Non-contact bearing system provides for dry run operation without damage to the pump. Self-radiating bearing system effectively transfers frictional heat from the bearing area to prevent damage during upset operating conditions.
The use of precision injection molded components results in consistent self-priming performance and product quality. No external chambers or valves required saving valuable installation space. Priming chamber only needs to be filled once for repeatable, fast priming.
The expanded SMX-F models all carry a full 2-year manufacturer’s warranty.
These pumps are perfect for transferring your most aggressive fluids from sumps, totes, rail car or tanker truck unloading, and top of tank transfer.
Iwaki America Inc.
www.iwakiamerica.com
Filed Under: Pumps, FLUID POWER, MORE INDUSTRIES
