Cleveland, Ohio – Keithley Instruments, Inc. (NYSE:KEI) announces the release of the Model 2100 6½-Digit USB Digital Multimeter (DMM), a high precision, low-cost USB-based instrument. The Model 2100 is ideal for a wide range of production test, burn-in, and manual and semi-automatic R&D applications in bench, portable, or small system measurement configurations and is available for a limited-time introductory price of only $795 USD.
High Precision and Accuracy
The Model 2100 features precision 10VDC accuracy of 38ppm 6½-digit resolution at a fast measurement rate of 50 readings/second (at 6½-digits) over the USB bus, a reading rate that is more than twice as fast as competitive offerings. At 4½-digits, the Model 2100 reads more than 2000 readings/second into its internal, 2000-reading data buffer.
Eleven measurement functions cover the most commonly measured parameters, including Volts, Ohms, Amps, and RTD temperature measurement capability, as well as MX+B, dB, and dBm math modifiers. Fully specified accuracies are valid for one year on all functions for ISO-compliant applications and facilities.
The Model 2100 also offers selectable front and rear inputs plus two- and four-wire remote sense resistance inputs that facilitate use as both a stand-alone, benchtop DMM or in small systems applications.
Supports a Wide Range of Applications
Keithley’s Model 2100 6½-Digit USB DMM is suited for test engineers performing manual and semi-automatic electrical function tests and development and R&D engineers performing electrical validation in emerging electrical design and manufacturing regions. It is also suited for service and calibration technicians working in instrument repair and metrology, research scientists, and engineering students in science and engineering laboratories.
Price and Availability
Keithley’s Model 2100 6½-Digit USB DMM is available for an introductory price of $795 USD through September 30, 2007. After that time, the list price will be $845.
For More Information For more information on Keithley's Model 2100 6½-Digit USB DMM or to order this product through the company’s online store, visit www.keithley.com/products/dmm/?mn=2100120
:: Design World ::
Filed Under: Data acquisition + DAQ modules, Multimeters, TEST & MEASUREMENT
