The 2706 Series PCB Terminal Strips bring lever-operated terminations to compact electrical applications. A UL/CSA 30 A/300 V rating and accommodation of conductors AWG 24–10 make the strips suitable for inverters, power supplies and other field-wired applications. Ranging from 2–12 poles, the strips provide a lever for each pole. Lifting each opens a CAGE CLAMP® Spring Pressure unit that remains open for conveniently terminating multi-conductor cables into the terminal strip. Lowering the levers creates an audible click, signaling that the units are secured. Pin spacing ranges from 7.5, 10 to 12.5 mm — the 12.5 mm variant achieves UL 600V certification.
WAGO Corp.
www.wago.us
Filed Under: Power supplies, ELECTRONICS • ELECTRICAL, Terminal blocks
