Locating Pins from J.W. Winco Offer Perfect Fit and Easy Installation
J.W. Winco, Inc. now offers series GN 771.1 Locating Pins in metric sizes. These RoHS compliant components are normally used in conjunction with DIN 172 / DIN 179 drill bushings.
JW-Winco-Locating-Pin
The tolerance of the pin diameter insures a perfect press fit into an H7 tolerance mounting bore, while the chamfer of the pin makes installation easy. The pins are made of steel, hardened to HRC 60 +/-2 and ground. Diameters run from 4 to 16 mm.
J.W. Winco
www.jwwinco.com
Speak Your Mind
