Carlo Gavazzi’s new PD140 Series Long Range Photoelectric Sensors is a product line targeted for Door and Gate Access applications. This sensor handles challenges found in the door and gate industry.
The design of the PD140 makes it a suitable choice for harsh outdoor use, where strong ambient light, fog, rain, snow, and dust, might be present. The aluminum and polycarbonate housing also protects the sensors against vandalism. The PD140 has an outdoor sensing range of up to 60 meters (200-ft), for controlled indoor environments, the range is up to 120 meters (400-ft).
As most installers know, installing and setting up infrared sensors at long distances can be challenging. With the optional APD140-LA01 Green Laser Alignment Tool, alignment of the PD140 can be done in seconds, even at distances longer than 60 meters (200-ft)! Full UL325 Certification ensures that the PD140 has the features necessary to meet the UL requirements for Door and Gate Access applications. The features of the PD140
Series Photoelectric Sensors include:
Aluminum and polycarbonate housing
Sensing range:
o Outdoor up to 60 meters (200 feet)
o Indoor up to 120 meters (400 feet)
Adjustable alignment: ± 100° horizontal, ± 15° vertical
Emitter mute (test input)
Two alignment tool options:
o Visible Green Laser (APD140-LA01)
o Voltage Output (APD140-TC01)
Crosstalk elimination with AC power supply and
synchronization mode (2 set)
SPDT relay contacts
12-24 VAC/DC power supply
IP65, NEMA 1, 2, 3, 3R, 3RX, 3SX, 3X, 5, 12 and 12K
rating
UL325 and UL508 Certifications
CE, EN12453, EN12445, EN12978 ESPE type 2,
Performance level d
The PD140 Door and Gate Photoelectric Sensors are available from Carlo Gavazzi’s North American
network of sales offices, distributors, and online at
Carlo Gavazzi
www.GavazziOnline.com
Filed Under: Sensor Tips
