MOtiCOnt’s VCDS-051-089-01 series linear motion voice coil stages feature a voice coil motor, a ball bearing linear slide, home switch, and an integral optical quadrature encoder with differential outputs. Measuring 13.5 in (342.9 mm) long x 4.00 in. (101.6) wide x 3.755 in. (95.4 mm) high, the VCDS-051-089-01 series stages have a linear travel of 2.20 in. (55.9 mm); a continuous force of 6.0 lbs (26.7 N) and a peak force of 19 lbs (84.3 N) at a 10% duty cycle. The high speed, high accuracy, and smooth motion of the VCDS-051-089-01 series linear motion voice coil stages are found in manufacturing, medical, aerospace/defense, and inspection applications such as: measuring, optical and electrical inspection, assembly, packaging, semiconductor handling, scanning, sampling, and pick -and-place robotics.
Available in standard models with positioning resolutions of 1 micron, 12.7 microns, 25.4 microns, and 29.95 microns, and with a 4.005 in. (101.7 mm) long x 3.000 in. (76.2 mm) wide stage, and convenient mounting holes, this series of high performance stages is easily integrated into new and existing applications. Other resolutions, higher forces, and customized linear motion systems can be quickly engineered to meet a user’s individual requirement. Complete Plug-and-Play systems are also available.
