Did you know, roughly 70% of bearing failure is caused by insufficient lubricant or lubricant contamination?
Upgrading your lubrication program with automatic lubricant dispensers can increase employee safety and reduce the number of lubrication related issues such as:
Bearing failure
Unexpected downtime
Over-greasing or Under-greasing
Contamination
A.W. Chesterton’s Lubri-Cup automatic dispensing systems provide the precise, metered amounts of lubricant to your critical plant equipment. They are fully programmable, easy to install, and come filled with Chesterton grease, in a variety of styles/sizes.
A.W. Chesterton
www.chesterton.com
Filed Under: Bearing Tips
