LVIT linear position product line expands into new markets
Alliance Sensors Group’s linear position product-line of LVITs (Linear Variable Inductive Transducer) has broadened to include three series, each targeting different applications. LVITs are contactless devices designed for factory automation and a variety of heavy duty industrial or commercial applications such as solar cell positioners, wind turbine prop pitch and brakes, chute or gate positioners on off-road or agri-vehicles, bridge expansion and rail sun kink monitoring, robotic arm position feedback, snow plow positioning, automotive/ motor sports, and packaging equipment. With their compact yet robust design, superior performance, and excellent stroke-to-length ratio, ASG’s LVITs are suitable for both industrial and OEM position sensing applications.
All LVITs Have the Following Features:
• Contactless operation prevents wearout from dither or cycling
• Ranges from 25 to 450 mm (1 to 18 inches)
• Radial cable exit version comes with swivel rod eye ends
• Four Analog outputs
• Axial termination versions with either M-12 connector or 1m cable
• ASG’s proprietary SenSet™ field scalability
LR-19- Automation Duty
The LR-19 has a ¾” OD aluminum body and is offered in ranges up to 200mm. The LR-19 is ideal for OEM and factory automation applications where small size and low cost are a premium.
LR-27 and LRL-27- Industrial Duty
The LR-27 and LRL-27 series are more robust than the LR-19 and is offered in both a 1” OD aluminum or stainless steel housing. The LR-27 is also for industrial OEM and factory automation applications where the application or environment is too extreme for the LR-19.
LV-45- Extreme Duty
The LV-45 series units were designed to survive the most extreme environments being installed on bridges, train tracks, and off road vehicles for construction and agriculture.
H. G. Schaevitz LLC / Alliance Sensors Group
www.alliancesensors.com
Speak Your Mind
