Camozzi Pneumatics offers a nickel-plated brass male swivel elbow with its Pro-Fit thread design, which allows assembly into female thread NPT (National Pipe Thread) as well as BSP (British Standard Pipe) forms.
The Pro-Fit thread design also eliminates exposed threads and fits into tight spaces, making it suitable for food processing and hygienic applications. The captured Teflon sealing ring provides a dependable and reusable shoulder seal without the risk of thread sealant contamination. Pro-Fit also eliminates the need for Teflon tape or pipe dope, and the shorter thread length means fewer turns are required to tighten.
In addition to the advantages of the Pro-Fit thread design, the company’s male swivel elbow is highly durable with all-metal, nickel-plated body, threads, collet and release ring. The materials offer better resistance to UV exposure, stress cracking, abrasion, solvents, detergents, hydrocarbons and other fluid media. The combination of compact size and lighter weight allow end-of-arm tooling and robotic handling, as well as reduced dimensions for valve assemblies, packaging applications and control cabinets.
Camozzi Pneumatics
camozzi-usa.com
The post Male swivel elbow for food processing applications appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
