Harsh environments pose difficult restrictions on measurements, especially when considering the sensor’s ruggedness and life. ASM designed the WB100M tape sensor for highly resistance to shock and operation to IP68/69K in sea water. With the POSITAPE range, the stainless steel measurement tape will have at least double the life compared to that of a measurement cable under identical operating conditions.
Available in a range of measuring lengths from 2,000 mm up to 10,000 mm and a range of analog or digital outputs including CAN SAE J1939, the linearity of the WB100M is rated up to +/- 0.05% full scale.
For more information about ASM’s WB100M tape sensor, click here.
