Housed in a 3D molded interconnect device (MID) package, 2E mechatronic’s MID-Thermic Flow Sensor can address several applications with tight space requirements. The injection-molded thermoplastic surface mount package of the MEMS-based flow sensor, measures 12 x 10 x 6mm³.
The sensor develops a pressure loss through a monolithically integrated flow channel using MEMS technology and scales the target differential pressure of the application.
The sensor can be used as a differential pressure sensor in bypass as well as in direct operation. The maximum volumetric flow in direct operation for air is 10 ml/min. With a response time of less than 10 ms and a power consumption of less than 10 mW, the sensor can be used for gases as well as liquids.
For more information about the MID-Thermic Flow Sensor, click here. An evaluation kit is available.
Filed Under: Sensor Tips
