With its hydraulics mounted outside the cab, the MESP 3016 from Muncie Power Products, Inc. reduces noise, heat, fumes and potential danger posed to the driver by high pressure fluids. The MESP 3016 Electronic Spreader Packages save salt and money.
Designed for easy set up, installation and operation, the MESP 3016 features automated ground speed controls. With this automation salt is distributed proportionately to the truck’s ground speed, reducing waste and cutting cost.
Nine programmable settings of operation and its compatibility with all spreaders, make the MESP 3016 a basic, yet efficient system.
The MESP 3016’s controller can operate in auto or manual mode. Durable, soft toggles and illuminated soft-touch buttons on the MESP 3016’s controller, make adjusting flow rates simple. Spinner flows up to 8 GPM and auger flows up to 17 GPM are achievable with this spreader package.
www.munciepower.com
Filed Under: Hydraulic equipment + components
