SCHURTER is expanding its metal switch range to include new illumination possibilities, through the use of RGB color technology. It is now possible for the piezo switch series, PSE, and mechanical switch, MCS 30, to have seven different ring illumination colors with just one switch. The multicolor illumination is powered by an integrated power supply that accepts an input voltage of 5 – 28 VDC.
The new multicolor illumination of the PSE and MCS 30 series is made easy using convenient color-coded wires in each of the illumination colors. The constant brightness intensity is maintained regardless of applied voltage. The standard version is offered in red, green, and blue. Additional color options include yellow, cyan, magenta and white, which can be made through additive color mixing. As soon as 2 or 3 wires are connected to the supply voltage at the same time, the result is a mixed color. The traffic light colors of red, green, and yellow (RGY) for status indication are also available as a standard version No additive color mixing is required to produce the color yellow.
The new RGB multicolor illumination option greatly expands the application range of the PSE and MCS 30 button style switches. The PSE is available in 22 mm, 24 mm, 27 mm and 30 mm diameters; the MCS 30 is available with a 30mm diameter. The PSE has an IP69K ingress protection rating. It has no moving actuator and is thus absolutely impervious to any leaks or accumulation of dirt underneath or around the switch surface. This technology is ideal for hygiene-related applications such as medical equipment, food processing equipment and outdoor applications subject to vandalism such as ticketing machines.
The MCS 30 is an alternative to the highly robust solid-state PSE. It is also designed for demanding applications, although it uses a tactile switch that provides a clear haptic feedback. It has a lifetime rating of one million actuations, as opposed to the PSE’s 20 million operations. The switch contacts are sealed from the front and rated IP65.
SCHURTER
schurterinc.com
Filed Under: Lights • signal lamps • indicators, Switches
