Ask yourself the following questions: Do you need a quick way to switch fluid power lines while maintaining a leak free environment either in your product design or testing facility? Does your design warrant a precision machined assembly that is easy to use, reduces down time and eliminates leaks? Is space limited? If you answered yes to any of these questions, then Beswick Engineering’s new dry break quick disconnects, QDM3I and QDM3E, are suitable for your demanding application.
The dry break quick disconnect reduces assembly time and prevents fluid from leaking out of the connector and damaging expensive electrical/mechanical systems. The disconnection is made by pulling a knurled sleeve back, which is not only easy to use, but also takes less than a second, saving costly downtime.
Designed with excellent sealing capabilities due to the minimized dead volume, the space between the internal and external ends when connected, leaks are non-existent when the two halves are disconnected. This is especially important when the fluid is a liquid or flammable gas.
Manufactured in corrosion resistant 303 stainless steel and manufactured with an M3 thread, both sides of the quick disconnect, internal and external, are fully shut-off prior to disconnection. Fast paced product development cycles are a reality with this design as assembly is quick and fluid leaks are eliminated.
Beswick Engineering
www.beswick.com
The post Miniature dry break quick disconnects appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
