Mitsubishi Electric Automation, Inc. has released its new RH-3SxHR robot that delivers improved throughput, superior positioning and a smaller footprint. The RH-3SxHR is a ceiling-mounted SCARA robot designed to maximize speed for picking and handling light-weight parts.
The RH-3SxHR extends Mitsubishi Electric Automation’s broad line of SCARA robots ranging from 3Kg-20Kg. Easy to install, this new robot is available in SD format, the traditional stand-alone configuration, and SQ format, the standard iQ-based configuration. Its compact design and overhead installation requires a smaller, less-expensive mounting structure, while its rigid construction provides improved strength and precision.
The robots are available as a Cleanroom version for semiconductor, medical, and pharmaceutical applications and as a Wash Proof version for food applications. They come with a two-year limited warranty and access to Mitsubishi Electric’s global support and service network.
Features
- High Speed – up to 188 parts per minute
- High Precision – 0.01mm repeatability
- Large Work Envelope – 700mm x 150mm work space (no dead-zone)
- High Payload – 3 Kg
- Light Weight – 24 Kg
- Two-Year Limited Warranty
Benefits
- Improved Throughput
- Superior positioning
- Reduced Overall Machine Footprint
- Diverse applications and tooling flexibility
- Ease of Installation
- Exceptional Quality and Dependability
www.MitsubishiRobotics.com
Filed Under: Factory automation, The Robot Report, Mechatronics
