The Thomas Model 2250 pressure/vacuum pump provides unprecedented levels of mobility and efficiency, combined with long life, in applications such as medical, analytical and air sampling equipment and office machines.
The quiet, low-vibration WOB-L® Piston design Model 2250 utilizes magnesium components that limit the pump’s weight to a mere 2.8 lbs. (1.27 kg). A highly efficient 24V brushless DC motor offers low power consumption and long life. The motor’s speed may be varied speed from 1,000 to 3,000 RPM, meaning the air flow can be controlled according to application need. In addition, an optional closed loop controller allows motor speed to be maintained at a pre-set, constant RPM regardless of load or voltage fluctuations.
The oil-less piston and cylinder design ensures clean, uncontaminated air flow up to 1.92 cfm (54.4 lpm).
Maximum pressure is rated at 30 psi (2.07 bar) and maximum vacuum at 25.9 in. hg (870 mbar).
Thomas
www.gd-thomas.com
Filed Under: Pumps, FLUID POWER, MOTION CONTROL
