The Rapidstar Supply Unit (RSU) for cooling lubricants comprises a range of low- and high-pressure valve blocks, filters and screw pumps for the tailor-made pressure supply in remote systems. The supply system reduces the piping needed and simplifies the mechanical setup. The KST booster moves the high-pressure generation into the hydraulic unit when internally cooled tools are used. Thus, the complete motor-pump supply line on the cooling lubricant side is omitted while the energy consumption is simultaneously reduced by up to 88%.
Boscg Rexroth AG
www.boschrexroth-us.com
Filed Under: Factory automation, Hydraulic equipment + components, Valves, Motion control • motor controls
