A full standard line of mounting components featuring various options for attaching something to a shaft, pipe, and tube has been introduced by Stafford Manufacturing Corp. of Wilmington, Massachusetts.
Stafford Mounting Components feature a variety of shaft collar designs and mounting options including face, flange, flat, and stackable as well as different fastening alternatives for securely mounting items to a shaft, pipe, and tube. Sizes range from 6 mm to 10” I.D., depending upon the configuration, they are available in steel, stainless steel, and aluminum, and special design modifications to customer specification.
Based upon one-piece, two-piece, and hinged shaft collars, Stafford Mounting Components include the Accu-Clamp feature for applications that require extreme squareness and flatness. For adjustable clamping without tools, Staff-Lok collars are offered or a Grip & Go Quick Release Handle which replaces a clamp screw to allow rapid repositioning can be added.
www.staffordmfg.com
Filed Under: Coupling Tips
