Molex Incorporated has launched a modular NeoScale™ mezzanine interconnect system capable of achieving optimal signal integrity at data rates of 28+ Gbps. Designed for printed circuit board (PCB) mezzanine applications in enterprise networking towers and telecommunication hubs and servers, in addition to industrial controllers and medical and military high data-rate scanning equipment, the NeoScale mezzanine interconnect features a patent-pending triad wafer configuration that isolates each differential pair for optimal performance and customization.
“The modular NeoScale triad comprises three pins per differential pair—two signal pins and one shielded ground pin. Each triad is a stand-alone 28 Gbps differential pair with no additional ground pins required and can be optimized for high speed single ended or power systems as well,” explains Adam Stanczak, new product development manager, Molex. “The highly flexible and robust NeoScale mezzanine interconnect offers exceptionally clean signal transmission and signal integrity compared to other mezzanine connectors available in the mezzanine connector market today.”
The honeycomb construction of the NeoScale mezzanine interconnect housing routes each triad to minimize crosstalk and effectively route out of the PCB in one or two layers, essentially saving designers in the cost of PCB material. In addition, unique tombstone structures located in the connector housing protect the mating interface and flexible contacts to help prevent damage to the terminals. Featuring a density of 82 differential pairs per square inch, the NeoScale layout can be customized with high speed differential pairs, high speed single ended traces, low speed single ended lines and power contacts. Available with 85 and 100 Ohm impedance and mated stack height range of 12 to 40mm, NeoScale design options include 6 to 30 circuit column sizes with 2, 4, 6 and 8 row options available, ranging from 12 to 240 triads in one assembly.
The NeoScale mezzanine interconnect deploys patented Molex Solder Charge Technology™ as an attachment method for PCB termination. More cost-effective and reliable than a ball grid array connector attachment method, the mechanical SMT process simplifies designs and facilitates strong solder joints in volume manufacturing by eliminating the need for thermal attachment and complex forms in the solder tail.
The NeoScale plug assembly features a 2.80mm pitch between differential pairs. The receptacle assembly pin includes polarization and keying features. The ground pin has two SMT attachment points, with four solder charge joints per triad and the PCB footprint does not change when mixing and matching the different differential pair, high speed single ended and power triads within the housing. The orientation of the NeoScale plug and receptacle provides a mirrored configuration with a dividing line of back-to-back shields. The resulting mirror line bisects the triad pair to facilitate PCB routing and RX/TX pin-out management for optimal signal integrity and mechanical stability. Durable molded construction further protects against handling damage and provides optimized signal integrity and mechanical stability.
“An ideal solution for space constrained designs with limited PCB real estate, the modular NeoScale mezzanine interconnect offers system architects and designers a durable and easily customizable design tool for a host of high density system applications,” adds Stanczak.
Molex
www.molex.com
Filed Under: CONNECTIVITY • fieldbuses • networks, Connectors (electrical) • crimp technologies, ELECTRONICS • ELECTRICAL
