Our Popular Easy to Use Brushless Motor Just Received a Boost in Power and Performance
Oriental Motor USA is proud to introduce our new 200 watt (1/4 HP) and 400 watt (1/2 HP) BMU Series Brushless Motor and Driver package.
The new 200 W (1/4 HP) and 400 W (1/2 HP) motors join the 30 W (1/24 HP), 60 W (1/12 HP) and 120 W (1/6 HP) family and continues the brushless motor advantage, such as flat speed torque curve, compact size, easy-to-use, easy-to-read digital speed indicator and torque output up to 610 lb-in (70 N-m). The 200 W (1/4 HP) BMU motor is now available in 100-120 VAC input and existing 200-240 VAC input. The 400 W (1/2 HP) BMU motor produces approximately 40% more starting torque than the 200 W (1/4 HP) motor and offers 100% more continuous running torque, creating significant advantages for applications that require larger loads.
The BMU Series is available in inch or metric geared output shafts and includes a 3 m (9.8 ft) motor cable.
The BMU Series’ 200 W (1/4 HP) and 400 W (1/2 HP) Models Key Features are:
- 200 W (1/4 HP) motor now available in both 100-120 and 200-240 VAC input.
- 400 W (1/2 HP) motor produces approximately 40% more starting torque than 200 W (1/4 HP) motor.
- Torque output up to 610 lb-in (70 N-m).
- Inch or metric geared output shafts.
Oriental Motor
www.orientalmotor.com
