New 30 million candlepower HID handheld spotlight
lightThe HL-85-HID-CPR handheld high intensity discharge spotlight from Larson Electronics is a lightweight, ultra rugged, ergonomic spotlight that operates on 12-24 volts DC with an included sixteen foot coil cord terminated in a cigarette plug. This high output HID spotlight is constructed with a single fifty-five watt HID lamp and features an advanced reflector and lens configuration to generate a 5,000 lumen light output. Drawing only 55 watts on a low voltage power source, this light produces a beam capable of reaching distances over 5,500 feet. An adjustable seven inch lens gives operators the ability to switch from a long, narrow focused spot beam of light to a wide flood beam of light with just a simple twist.
This IP65 rated waterproof HID spotlight features an ultra-durable ABS shockproof polymer body, aluminum alloy light head housing, and an impact resistant polycarbonate lens. The unique shape and shallow contour of the seven inch reflector is paired with a convex lens and inset lens positioned to efficiently capture and project a focused beam of light while reducing light spillage. The pistol grip style, nylon handle has a no-slip textured surface to improve grip and has a conveniently placed push button so that the user can easily access the switch with the fore finger for quick on/off operation.
Larson Electronics
Larsonelectronics.com
Power Electronic Tips
