New Portescap Motor
The Portescap h3 Stepper Motor is a 1.8° step motor with an aluminum housing for sufficient heat dissipation to create high output torque during operation. The stator-enhanced magnets deliver up to 40% more torque in the same footprint. Neodymium iron boron magnets enhance torque density, while the bearing retainer and o-ring help reduce motor noise. Larger bearings enable the motor to effectively handle higher side and radial loads.  These motors are available in NEMA 17, 23 and 34 frame sizes. Various stack lengths are available in each frame size, and windings can be customized to suit individual application needs.
Portescap, a Danaher Motion co.
:: Design World ::
Speak Your Mind
