New, mid-range capacity, 7 Series Solenoid Valves are designed with a powerful, but economical coil capable of handling pressures up to 250 PSI his versatile valve series with its overmold coil and construction performs well at high temperatures, is moisture resistant and can be configured in a low-profile option for difficult installations.
The high-performance, low-cost characteristics of the 7 Series makes them ideal for use by OEMs in automotive applications like suspension systems, emissions monitoring, fan clutch controls and control equipment, dental/vision or medical applications, tables and beds liquid recycling systems, HVAC and many other applications.
This direct acting solenoid valve series is available in 2-way and 3-way designs, and features 1.25″ x 1.63″ and manifold mount body types machined from aluminum, brass or stainless steel with 1/8″ or 1/4″ NPT ports and orifice sizes from 3/64″ to 1/4″ with a standard 11 watt coil that can operate on either AC or DC service. The 7 series is available with both spade and lead connections.
Solenoid Solutions Inc.
solenoidsolutionsinc.com
Filed Under: Valves
