Steute Industrial Controls offers a comprehensive line of Wireless, Batteryless Limit Switches. These Wireless Limit Switches feature an internal electrodynamic energy generator. No battery required. Displacement of the actuator generates power to send a uniquely coded signal to one or more compatible, easily-programmed Receivers. If the limit switch does not receive the confirmation signal within 15ms, it transmits a second signal. The Receiver accepts up to 10 discrete signals per channel.
Steute Limit Switches Features:
- Available for operation at 915 MHz (USA/Canada/Australia) or 868 MHz (Europe)
- Maximum transmission range: 40 m indoors, 450 m outdoors
- Bidirectional communications with Receiver confirming receipt of signal
- Limit switch signal configurable at Receiver (e.g. NO, NC, other)
- Ingress protection rating: IP67
- Mechanical life expectancy: > 1 million actuations
- Operating temperature range: -20°C to + 65°C
- Certifications: FCC, IC (for SW915 MHz models), EC (for 868 MHz models)
Options:
- Variety of actuator styles (e.g. roller plunger, roller lever, rocker lever, spring rod, others)
- Transmission range extenders
Steute
www.steute.com/en
Filed Under: MOTION CONTROL, Switches
Dr David Deak says
They use a backup battery in their so-called battery-less wireless switches
