Novotechnik, U.S. RFC4800 Series of touchless angle sensors can measure angular position up to 360° for a revolution counter and speed measurements. The RFC4800 Series of Hall Effect sensors includes programmable zero point offset, measurement averaging and sign of rotational direction and has a resolution of 14-bits across 360°, repeatability of 0.36° and independent linearity of ±0.5% of full scale.
In addition to the availability pf Single and multi-channel versions, output interfaces options include IO-Link, analog voltage and current, as well as digital outputs options—SSI, SPI, incremental and CANopen.
With operating temperature range of -40 to +125°C and the sensor’s packaging sealed up to IP69K, mean time to failure is 76 years.
For more information, click here.
Filed Under: Sensor Tips
