It is more than twenty years since Société des Traversiers du Québec (STQ) retrofitted Thordon Bearings’ water lubricated propeller shaft bearings to the double-ended ferries Armand-Imbeau and Jos-Dechênes, as part of an ambitious vessel modification project.
It was in 1996 that STQ decided to lengthen each of the ferries by 19.2m (63-ft.) to increase passenger and vehicle capacity. The project required an upgrading of the original engines to deliver greater power for a cruising speed of 12kts and modifications to the shaft to accommodate a water lubricated arrangement. The original oil lubricated stern tube bearings were replaced with a 279.5mm (11-in.) COMPAC bearing aft and a larger 299.5mm (11.8-in.) COMPAC bearing sited fwd.
Commenting on STQ’s decision to only use water lubricated propeller shafts, Scott Groves, Business Development Manager, Thordon Bearings, said: “Over the last few years, STQ has gradually renewed or replaced its fleet, with all of the vessels now operating COMPAC water lubricated propeller shaft bearings. This is testament to the performance, reliability and robustness of the owner’s first COMPAC installation, more than twenty years ago.”
Jasmin Racicot, Technical Development Director at RMH Industries, the Canadian engineering company that supplied and supervised STQ’s initial and subsequent water lubricated propeller shaft installations, commented: “We have been involved in all of the shipowner’s COMPAC installations. We have also supplied STQ with Thordon’s Water Quality Package which ensures the bearings deliver optimum efficiency when operating in some of the toughest marine environments.”
Thordon Bearings
thordonbearings.com
Filed Under: Bearing Tips
