The OMEGA OM-SGD Series of panel meters with bright color TFT smart graphics displays are available in three screen sizes. They offer a wide operating power supply voltage range of 4 to 30 Vdc and two alarm outputs. Waterproof NEMA 6 (IP67) versions are also available.
Using the provided Simple Wizard-based configuration software, select from over 40 standard display configurations to program in seconds to your exact requirements. Customize colors, text labels, input scaling and units before uploading the selected display configuration to the meter through a USB interface to the PC.
The OM-SGD is ideal for process monitoring in a wide range of industrial or laboratory applications in the following industries:
- Chemical,
- Automotive,
- Water,
- Petroleum,
- R&D,
- HVAC,
- Electronics and
- semiconductors.
OMEGA Engineering
www.omega.com
Filed Under: Automotive, ENGINEERING SOFTWARE
