Omron-Yaskawa, the European market leader in industrial inverters, announces the launch of the V1000 Compact Inverter series — the world’s most dependable inverters and the pinnacle of the highly successful inverter family. The European preview will be held at the SPS/ IPC/ Drives 2006 event in Nuremberg (Germany), Hall 9, Booth 9-330.
10 x 100 = 1 – Quality has a new formula
As the market’s largest and most trusted supplier of inverters, Omron-Yaskawa is driven by quality and has made a habit of building this into its inverter families. But this quality now has a new formula, 10 x 100 = 1, because the V1000 breaks with all conventions and constraints.
The innovative design together with modern manufacturing techniques means that Omron-Yaskawa can promise at least 10 years trouble-free operation with the V1000. Moreover, its features and performance guarantee a 100% match with the expectations of users, such as machine builders. Beyond this, a field-failure rate of less than 1 in 10,000 means that it will continue to outperform all other inverters long after the average service-life expectancy is over.
Fewer parts — more reliability
Omron-Yaskawa has achieved this new formula for quality and dependable performance by taking enormous strides in design efficiency. Not only has its volume been reduced by up to 40% to save mounting space, the V1000 actually uses 50% fewer mechanical parts than its predecessors. This considerably reduces the risk of component failure.
Performance guaranteed
The V1000 is able to increase the output current by around 20% when moving down in frequency carrier, thanks to its double rating. The standard setting is constant torque (CT : 150% rated current / 1 min) and increasing output current when in the variable torque mode (VT : 120 % rated current / 1 min.).
Current Vector control with smart continuous tuning
Unlike any previous inverter, the V1000 delivers optimum speed control and high starting torque thanks to the current vector control. And it is improved even further with a smart on-line tuning feature that takes ‘auto-tuning’ to a new level. On-line tuning is a method of continuous tuning. It ensures that any temperature deviation large enough to affect electrical parameters governing the motor speed will be adjusted before any variance in speed can occur.
Time-saving safety feature
Safety is embedded in the V1000 from the inside out, making it easy to integrate the inverter into a machine system and avoid difficult connections to safety controllers. Dual safety inputs (acc. To EN954-1 Safety Category 3) disconnect the motor faster at the first sign of trouble.
http://www.omron-industrial.com
Filed Under: Factory automation, Appliance engineering + home automation, Machine tools + subtractive manufacturing, Automotive, Packaging, Motion control • motor controls
