Dallas-based Orion Fans, a division of Knight Electronics and a leading manufacturer of standard and custom AC and DC fans, fan trays and accessories, has developed a thermally-controlled series of DC fans designed for electric vehicle (EV) battery cooling applications. The smart fans reduce power consumption by up to 30%, as the thermal controller increases or decreases fan speed in response to the air temperature. In addition to providing superior energy savings, the fans’ high airflow help prevents premature electric vehicle battery failures. Orion Fans’ thermal management solutions also can include heat sinks and special voltages when needed.
The temperature-controlled smart DC axial fans feature a ball-bearing design that extends the life expectancy of the fan while significantly reducing noise levels. Orion Fans temperature- controlled smart DC axial fans are available in a wide variety of dimensions, voltages, and airflows to meet most any application requirement. The OD2510 Series, for example, can provide airflows ranging from 1.8 CFM to 3.2 CFM in a 25mm x 25mm profile, while the OD254 Series provides airflows of up to 850 CFM in a 254mm x 89mm profile. Orion Fans can also deliver custom cooling solutions to meet customer needs.
Orion Fans
www.orionfans.com
Filed Under: Drives (ac) + VFDs + starters, MOTION CONTROL, Motors • ac
