Osborn has introduced a line of Needle Roller Cam Followers to its Load Runners division.
Osborn’s 191 SKUs of Needle Rollers are available in a standard range of sizes. Needle Rollers are lightweight and because of the rollers’ low sectional height, can handle high radial load capacities. Other advantages of Needle Rollers include improved mechanical efficiency from their low rotating torque, minimized inertia when the bearing is put in motion and the ability to suit many oscillating motion applications.
“The Needle Rollers’ cost effective and lightweight design and strong radial load capacity allows machine builders to design more compact machines, saving space and costs for the manufacturers buying them, said Spencer Maheu, director of marketing and product management at Osborn ”
Osborn
loadrunners.osborn.com
The post Osborn introduces needle rollers to load runners division appeared first on Bearing Tips.
Filed Under: Bearing Tips
