Sunclix dc plug and receptacle connector system from Phoenix Contact, Middletown, Pa., is designed for photovoltaic (PV) applications. The connectors can be assembled in the field or factory, greatly reducing the cost of installation.
The one-piece dc connectors use spring technology for quick and easy assembly and termination, without the use of crimp tools. The connectors can only be disconnected with the use of a screwdriver. This eliminates the possibility of accidental release, while meeting NEC requirements.
The new plug-in connectors make it possible to connect PV conductors from 14 AWG to 6 AWG, and with voltage of up to 1500 V IEC using only two versions. The connectors classified with IP69 degree of protection (2 m/24 h) meet the requirements of the DIN EN 50521 standard and are ETL-certified to UL subject 6703.
Phoenix Contact
www.phoenixcontact.com/sunclix
The post Plug and receptacle connector for photovaltaic applications appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips
