Coilhose Pnuematics’ D.O.T. tubing is a Type A, non-reinforced nylon tubing used for connecting instrumentation and accessories for air brake systems. It is manufactured from high quality resins and has a temperature range from -60° to 200° F. The tubing meets UL94HB compliance and is UV stabilized. There are five models available: the DOT18, DOT532, DOT316, DOT14 and DOT516.
DOT18
- 1/8 in. outside diameter, .079 in. inside diameter
- Bend radius of 3/8 in.
- Burst pressure of 1,000 psi
- 5/32 in. outside diameter, .092 in. inside diameter
- Bend radius of ½ in.
- Burst pressure of 1,200 psi
DOT316
- 3/16 in. outside diameter, .117 in. inside diameter
- Bend radius of ¾ in.
DOT14
- ¼ in. outside diameter
- .170 in. inside diameter
- Bend radius of 1 in.
DOT516
- 5/16 in. outside diameter, .232 in. inside diameter
- Bend radius of 1 ¼ in.
Coilhose Pneumatics
coilhose.com
The post Pneumatic tubing for air brake systems appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
