Sensing position in a deep sea environment requires withstanding salt water and high pressures. Those are two of the design goals for Macro Sensors SSB/SSBR series LVDTs. The submersible position transmitters have CANopen interface compliant to CiA 443 for subsea instruments. In addition to surviving salt water, the units can handle external pressures up to 7500 psi.
The 0.94 inch (24 mm) nominal diameter sensors are available in standard ranges of 2.00 inches (50 mm), 3.00 inches (75 mm), 4.00 inches (100 mm), or 8.00 inches (200 mm) with other ranges available at special request.
For more information, click here.
Filed Under: Sensor Tips
