Power Triple Lock Connector System now distributed from Sager Electronics
Sager Electronics is now stocking TE Connectivity’s Power Triple Lock connector system.
TE’s Power Triple Lock connector system offers high performance with a functional design. From the audible lock to the many added customer benefits, the Power Triple Lock connector system has been specifically developed for better power and signal applications. For 3-in-1 reliability, the system offers 3 enhanced methods of connectivity, making design connections better in every way.
The connector position assurance (CPA) device locks the cap and plug together. The terminal position assurance (TPA) device helps assure terminals are fully seated and remain that way. Three material options support standard 105°C, high temperature 150°C and glow wire applications. Four keying options, multiple colors and snagless design features help assure fast, accurate connections. Up to 15 positions are offered on 6mm spacing.
TE Connectivity’s Power Triple Lock connector system is in stock at Sager Electronics. If you’d like to learn more about the Power Triple Lock connector system, visit https://www.sager.com/manufacturers/te-connectivity/te-introduces-power-triple-lock-connector-system/default.aspx.
Sager Electronics
www.sager.com
Speak Your Mind
