Pre-wet packages are available in hydraulic and electronic drives. Muncie Power’s hydraulic pre-wet features three different models with 15 GPM max hydraulic flow, independent hydraulic or auger exhaust options and a maximum liquid pressure of 100 PSI.
The electronic pre-wet has two models available, one with 3 GPM (10 Amp) and one with 6.25 GPM (20 Amp). Each of the electronic pre-wet models has a maximum output pressure of 45 PSI.
All products have proportional electronic control for greater accuracy.
Open and closed loop models are available in most configurations.
Muncie Power Products
https://www.munciepower.com/prewet
