Pressure vacuum pumps
Vacuum pumps can be a key component in packaging applications. The 2755 series variants are: 2755BE75, 2755BGHI75, 2755CE60, 2755CGHI60, 2755TE48/40. 2755TGHI52/48, 2755VEF75, 2755VHI75. These oil-less twin WOB-L piston units are RoHS compliant and designed for single stage vacuum, two stage vacuum, single stage compressor, or two stage compressor operation. They are designed for applications including blood or laboratory analyzers to ozone generators to packaging equipment, just to name a few.
The 2755BE75 (115/60/1) is UL approved and provides an open flow of 7.5 cfm (212.4 l/min) and can operate up to 93% of local barometer continuously. It weighs 21.5 lb (9.8 kgs) and measures (L x W x H) 10.35 in. (262.9 mm) x 5.37 in. (136.4 mm) x 9.32” (236.7mm).
The 2755BGHI75 (230/60/1 & 220-240/50/1) is TUV approved and provides an open flow of 7.5/6.6 cfm (212.4/186.9 l/min) and can operate up to 93% of local barometer continuously. It weighs 22.6 lb (10.3 kgs) and measures (L x W x H) 10.35 in. (262.9 mm) x 5.37 in. (136.4 mm) x 9.32 in. (236.7mm).
The 2755CE60 (115/60/1) is UL approved and provides an open flow of 6.5 cfm (184.0 l/min) and can operate up to 15 psi (1.0 bar) or 91% of local barometer continuously. It weighs 21.5 lb (9.8 kgs) and measures (L x W x H) 10.35 in. (262.9 mm) x 5.37 in. (136.4 mm) x 9.32 in. (236.7mm).
The 2755CGHI60 (230/60/1 & 220-240/50/1) is TUV approved and provides an open flow of 6.5/5.6 cfm (184.0/158.6 l/min) and can operate up to 91% of local barometer continuously. It weighs 22.6 lb (10.3 kgs) and measures (L x W x H) 10.35 in. (262.9 mm) x 5.37 in. (136.4 mm) x 9.32 in. (236.7mm).
The 2755TE48/40 (115/60/1) is UL approved and provides an open flow of 2.6 cfm (73.6 l/min) and can operate up to 160 psi (11.0 bar). It weighs 21.7 lb (9.8 kgs) and measures (L x W x H) 10.75 in. (273.1 mm) x 5.37 in. (136.4 mm) x 9.32 in. (236.7mm). Unit comes standard with fan guards and ground wire.
The 2755TGHI52/48 (230/60/1 & 220-240/50/1) is TUV approved and provides an open flow of 2.75/2.30 cfm (77.9/65.1 l/min) and can operate up to 175 psi (12.1 bar) continuously. It weighs 23.0 lb (10.4 kgs) and measures (L x W x H) 10.75 in. (273.1 mm) x 5.37 in. (136.4 mm) x 9.32 in. (236.7mm). Unit comes standard with fan guards and ground wire.
The 2755VEF75 (115/60/1 & 110/50/1) is UL approved and provides an open flow of 3.9/3.4 cfm (110.4/96.3 l/min) and can operate up to 98% of local barometer continuously. It weighs 21.5 lb (9.8 kgs) and measures (L x W x H) 10.35 in. (262.9 mm) x 5.37 in. (136.4 mm) x 9.32 in. (236.7mm).
The 2755VHI75 (220-240/50/1) is TUV approved and provides an open flow of 3.4 cfm (96.3 l/min) and can operate up to 98% of local barometer continuously. It weighs 22.6 lb (10.3 kgs) and measures (L x W x H) 10.35 in. (262.9 mm) x 5.37 in. (136.4 mm) x 9.32 in. (236.7mm).
Units include a cathodic epoxy coated monolithic head, cathodic epoxy coated wetted parts, quality die-cast aluminum components, as well as more robust design features that utilize best practices from other product series. Supplied standard with each unit is a capacitor, capacitor insulator boot, and intake filter.
Gardner Denver THOMAS
www.gd-thomas.com
Speak Your Mind
