TDK Corporation announces the introduction of 800W high voltage models to TDK-Lambda’s Z+ series of programmable DC power supplies. The series is now available with output voltages of
-10, 0-20, 0-36, 0-60, 0-160, 0-320 and 0-650VDC with output powers of 200 to 800W. These higher voltages address the requirements for applications such as deposition processes, remotely operated underwater vehicles, ATE systems as well as general laboratory and industrial use.
Carrying a 5-year warranty, the TDK-Lambda Z+ 800W high voltage models have the same features and compact dimensions (2U high and 2.76” wide) as the existing models and achieve efficiencies of up to 89%. The units can operate in either constant current or constant voltage modes and accept a universal 85-265VAC input. Up to 6 units can be connected in parallel (master-slave configuration), or 2 identical units in series with external diodes.
All models can be programmed via the front panel controls or remotely using the USB, RS232/485 or analog control interfaces. Optional LAN, GPIB (IEEE488) and isolated analog programming interfaces are also available.
CE marked for the EMC, Low Voltage, and RoHS Directives, the Z+ series conforms to EN55022/EN55024 as well as IEC/EN61326-1 for conducted (FCC part-15-B) and radiated (FCC part-15-A) EMI. Safety certifications include UL/EN/IEC61010-1 and the series is designed to meet UL/EN60950-1.
Major applications
Deposition processes, remotely operated underwater vehicles (ROV), ATE systems and general laboratory / industrial use
Main features and benefits
- Built in analog, USB and RS232/485 interfaces
- Optional LAN, GPIB and isolated analog programing
- Bench or rack mount
- Constant current or voltage operation
TDK-Lambda
www.tdk-lambda.com
Filed Under: Power supplies, Power Electronic Tips
