The Guardian™ hose sleeve protects equipment operators from potential injuries resulting from hose failures. The sleeve’s ultra tight, polyamide 6-weave construction restrains hose bursts at pressures up to 16,000 psi, deflect 1 mm pinhole leaks at 4,000 psi, and provide durability of up to 250,000 abrasion cycles.The sleeve is compatible with the majority of chemicals associated with fluid-conveyance applications. It meets the new “Line of Sight” operator protection regulations EN982 ISO norm 833 EN414 and ISO 3457, as well as industry standards for abrasion and flame resistance. The sleeve is available for -4 though – 24 hose sizes.
Eaton Corp.
www.eaton.com/hydraulics
Filed Under: Hydraulic equipment + components, FLUID POWER, INDUSTRIAL SAFETY SYSTEMS
