NCC Automated Systems – Noise eliminated with Tray-Express Modular Transportation
The Tray Express System relieves this noise by using a smooth belt conveyor at the accumulation points and flexible chain at the curves. Most systems can be retrofitted with the pallet style of conveyor and keep the same chain conveyor depending on the age of the conveyor. Many times those conveyors removed can be used in other parts of the facility so as to not waste any conveyors at all. Tray Express is pre-engineered and pre-assembled which reduces complexity with easy installation and support. This offers a plug & play system for quick production startup. The system also offers an intelligent routing concept where the job trays are automatically routed to the next available process station, processed job trays are then discharged from the loop on a separate track.
Tray Express Features:
-Auto-stacker and destacker
-Quiet Tray Transfers
-Lift and Transfer Unit
-Zero Pressure Accumulation
-AC Voltage Options Available 110-460-VAC
-New 24VDC Drive Option
NCC will be exhibiting Tray Express with Satisloh at the Vision Expo, New York, NY booth LP7121.
www.nccas.com
Filed Under: Factory automation, Material handling • converting
