Removable Top Linear Shaft Supports
Ondrives.US Corporation announces the only removable top low profile linear shaft supports. By using top loading, you’ll have easier assembly and your customers will accurate re-alignment of shafts and bearings when needed with less downtime. The removable top allows quick replacement without the loss of alignment position.
Ondrives-US-Removable-Top-Linear-Shaft-Supports
These patent pending LPB Shaft supports are also low profile, only 0.87″ high for 0.25 shaft diameter. For shaft diameters from .2500″ to 2.000″ in 9 sizes. Metric bores available. They are RoHS compliant. They are precision manufactured in aluminum, are gray anodized and have alloy steel fasteners.
Ondrives US Corporation
http://ondrivesUS.com/support_LPB.htm
Speak Your Mind
