Yokogawa Corporation of America announces the sales release of the next step in retractable fittings, the Model PR10.
The PR10 was developed to address the changing needs from the process industry, for retractable sensor assemblies that offer a flexible approach for online applications, where the sensor must be removed safely without interrupting the process. The PR10 has versions suited for pH, ORP, Conductivity and Inductive Conductivity measurements.
There is a wide range of adaptors, ball valves and flanges available for the PR10 assemblies to address a variety of process installation requirements.
To minimize maintenance requirements, the PR10 was designed with fewer o-rings and a built in “scraper” has been included to minimize process intrusion when the assembly is retracted. An optional flush port makes it easy to keep pH sensors moist and clean, and also provides access for calibration.
In addition to Yokogawa’s standard pH and ORP combination electrodes, the PR10 offers a version that accommodates all commercially available pH electrodes with PG 13.5 mm thread or DIN connections.
www.yokogawa.com/us
Filed Under: SENSORS, TEST & MEASUREMENT
